ol_Bombero-JC
Jul 17, 2014Explorer
Me Again wrote:
Or just remove the shocks and give it a try. They only have minimal value anyway.
Yikes! - "minimal value anyway"
If you ever had a trlr *without* shocks - then added them, you would/should know the "shocking" night & day difference!.:R
"Minimal value shocks" (car/truck or trailer): they are most likely OEM and (way) overdue for replacement.
BTW - If you don't need shocks - take the shocks off your car or truck!..:S..:S
OP: You did excellent homework.
Suggest:
1. Michelin XPS Ribs in the size you stated.
2. *If* you feel you don't have adequate clearance between tires & shocks (appears to be a bit more than 1/4 inch which is "tight") - move the shocks further inboard, which is no big deal.
Sometimes the fender supports are easily bent to provide clearance.
Wheels - supplier not important. Wheels = Alcoa.
Buy and try *one* - with the caveat....for "test purposes" (no on-the-road time) - if it doesn't provide the clearance you want, the tire & wheel are "returnable".
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
