Me_Again
Jul 19, 2014Explorer III
camperkilgore wrote:
Beginning to wonder about the wisdom of using more expensive LT tires. I did the same thing after losing tires to blowouts. The original tires on our fiver were the Chinese made tires, so I went from 15" to 16" tires and switched to BFG commercial TA tires. We made three trips to western states from Florida with no problems, but three years later, lost the tread on one and discovered another had problems with separation and was ready to go at any time.
So at this point I'm beginning to think that it might(MIGHT) be better to go with ST tires with stiffer sidewalls, but make sure that I replace them every 2 1/2 to 3 years. Being proactive about it might prevent a lot of aggravation down the road. Being able to locate the best deal when replacing all four would be better than getting stuck with a bad deal when out in the boonies some where.
This is a plan that would probably make the most sense for me based on my particular camper and my experiences with that camper. Your mileage may vary.
ST tires do not have stiffer side walls vs most LT tires.
If you are keeping the trailer for many years then XPS RIBs or R250s will be cheaper in the long run with 6 to 8 years of use, then sell them on CL. I got $200 for four 6.5 year old RIBs.
No other tire comes close to one of these two on 5200 or 6000 axles. I have used both. We do the 1650 miles between NW Washington and Arizona in 3.5 days and never worry about tires. Nice thing is our trailer placard list LT235/85R16E, so the eagle and tire companies can not play their games with us.
Chris
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 22, 2026
