Cummins12V98
Jul 21, 2014Explorer III
jaycocamprs wrote:MM49 wrote:
I wouldn't recommend a LT tire, but if you are determined to, the Hercules H-901 looks like an interesting G rated, all steel tire.
MM49
Hercules Tire
Why would anyone need G rated tires on a trailer with 5200# axles? When I did a swap on a 9K trailer, any more than 70psi in a BFG LT235/85R16/E would not make contact across tread. Those tires lasted 5 years, 2 on the JayFlight, 3 on the Mountaineer. I replaced them with R250's this summer
We have a winner!!!!!!
When changing to a higher load rating tire use the tire weight/inflation chart to properly air your tires. Don't just blindly fill tires to MAX PSI!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
