Me_Again
Aug 11, 2014Explorer III
ah64id wrote:Me Again wrote:ah64id wrote:
Goodyear allows the Marathon ST tires to run 10psi over the chart or sidewall pressure, which increases the speed rating from 65 to 75.
I am on my 2nd TT and they have been on both, lots of miles and rough road miles. I haven't had any issues I can blame the tires for, just 2 flats from rock punctures on some nasty forest service roads.
I will need new tires next year and will go back to the 225/75R15 Marathon in LRD, I max them out at around 80% of their load rating.
I thought it was over chart but not to exceed max sidewall?
Chris
The press release I saw says 10psi above the placard limit, if the wheels and valve stems are rated for it. There is nothing that limits that pressure to the sidewall pressure.
So you know this is the 5th wheel section and they seem to be much harder on cheap ST tires, right? Your bumper pull is much lighter than most 5th wheels running ST tires to early failure.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
