ol_Bombero-JC
Aug 12, 2014Explorer
ah64id wrote:
Goodyear allows the Marathon ST tires to run 10psi over the chart or sidewall pressure, which increases the speed rating from 65 to 75.
I am on my 2nd TT and they have been on both, lots of miles and rough road miles. I haven't had any issues I can blame the tires for, just 2 flats from rock punctures on some nasty forest service roads.
I will need new tires next year and will go back to the 225/75R15 Marathon in LRD, I max them out at around 80% of their load rating.
Many/some of "us" who had TTs in the past - also had Marathons.
They did just fine on my previous 20' & 24' Terry TTs.
(However, I switched to non-GY LT tires on the 24 long before I sold it.)
Many are/were aware of the GY 10psi "permitted" increase.
GY made that one disappear - although it still can be found out there in cyberspace.
That may have been about the time they lost the lawsuit, which included Marathons for RV use. (Google: "Goodyear kept tire problems quiet")
As already noted - 5th wheels and ST tires are *not* a good combo!
Since you are a TT guy, here's a lengthy thread from the Airstream forums about your tire choice..:C
Seems a lot of the Airstream TT owners do *NOT* share your warm feelings for Goodyear Marathons on their TTs..:(
It should be termed.... a *Marathon* about - GY Marathons!...:B
Air Forums: "Goodyear Marathon Failures"
BTW it ran from 11-29-06 to 5-3-2011, then to a link for a poll at post #678 - which continues in a new thread with comments/posts thru 2014.
Apparently a "never ending" saga!..:R
Maybe you should post your success story there for a comparison..:@
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 18, 2026
