cummins2014
Oct 15, 2021Explorer
Water Heater bypass valve.
Went out to winterize the fifth wheel today ,turned the bypass valve to bypass, turned the water inlet connection to winterize . hooked up the short hose to the inlet connection , then into the gallon jug of antifreeze . Went in the fifth wheel ,turned on the pump ,opened up the kitchen faucet got a little water coming out, but not much. Went back out ,and the jug of anti freeze was empty, and I could see where the antifreeze had been running out the water heater ,I had the plug out. So I turned the bypass valve back ,and forth a couple times from normal to bypass , and tried again , same results .
This is the second winter I have had the fifth wheel, no issues last year when winterizing. Its a simple task. Turn to bypass ,and turn the water inlet to winterize ,and get after it. My question at this point do those manual bypass valves go bad ,hard to imagine they would, but can't think of another reason its not bypassing the water heater . Any thoughts before I order a new one, and replace ??
