djousma wrote:
naturist wrote:
Sorry to hear you were afflicted and I do hope the repairs needed are less than you expect.
First time we used the shower in our then-brand-new TT, the bathroom floor flooded. Turned out the guy who installed the trap under the shower floor pan didn't bother to tighten the collar, so it was easy to fix. Sent me looking at all the plumbing fittings.
Same here in my 2017 Cardinal. Not only was the collar loose, and luckily wasn't leaking, but the shower enclosure wasn't caulked at all, and we ended up with water running out the bottom of the brand new 5th, the second day we had it. Talk about pissed off. That was while on full hookups. A week later, july 4th weekend, we are at campground on fresh water tank only, and I see dripping out the bottom of the trailer on the side that the pump is located. Pull out the bulkhead and find the water connections to the pump aren't even finger tight....
A real lack of QC these days.
I'm not sure that it's a lack of quality. All that bouncing on the road is naturally going to loosen up any screw on type water fitting. Checking that they are tight is a part of routine maintenance. Unfortunately this isn't mentioned in most manuals. Often people (myself included) learn that this has to be done after finding a puddle somewhere in the RV.
