lincster
Nov 03, 2017Explorer
Ok, then your trailer never got the "frame upgrade.
the gussets you see are normal and are standard.
The upgrade adds more support in the wheel wells and adds cross bracing from side to side, under the trailer.
Warrior's are notorious for having "saggin walls".
It is a weird name because the root cause is the floor actually is pushed up over time.
You can tell if you have it bad as you will see a gap between your counter and the wall, or the fridge and the wall.
Some say if you bounce up and down in the back, by the ramp, and it bounces alot, then you have it. I'm not convinced of this.
Anyway, you were asking for things to look out for and this is one.
There is a guy, Jim, in So Cal that used to work for Warrior back in the day. He is doing his own thing now, but he does absolutley phenomenal work.
If you really want to have your trailer gone through/upgraded or whatever, he is the guy to take it to.
I will warn you, the frame upgrade runs about $3-4k.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
