taken
Sep 07, 2015Explorer II
Sounds like your battery master disconnect is shut off. When you start the genset, it powers your converter which provides 12V and runs your trailer. Normally when your genset is shut down and your converter looses 120V your rig will run on battery. However if the batter disconnect is shut off, it's lights out. So, if your only getting 12V with the generator running, that means it's coming from the converter and not the batteries. Look for this and see if it's turned on:
Or this:
Or this:
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
