Camorhino
Jul 10, 2013Explorer
Out off all my pics, I don't have one of that :( Trailer is in Vegas, and I'm in CA. But it is simple to do. Takes longer to unscrew the door flange, and the water line off the back. You want to use a wall mount hose bib for the appropriate angle of the hose threads in the door, and just remove the pvc nipple from the backing plate, shorten the large pipe to the length that works for you, and rivet it back on to the door flange. Once you get it out so you can see the workings of it, you'll be okay. Mine is a '08 CL 4005, but I think they used the same fittings/ compartment in all of them. I actually cut my large pipe length about a 1/2" too short, and had to turn the faucet handle just so, in order to close the door, but it works great.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
