Nabber86's avatar
Nabber86
Weekend Warrior Water Tank
Does anyone know what type of plastic Weekend Warrior water tanks are made from? I was tearing up and replacing the flooring and grazed one of the freshwater tanks with a sawsall. It's a small cut and I have been reading up on plastic welding. I can get a welder for about $70 at Northern Tool and the welding process seems pretty easy. The only problem is that you have to know what type of plastic that you are working with and get the right plastic "welding rods". I figure the plastic is HDPE, LDPE, or polypropylene. Does anyone know which plastic I should get.
The model is a 2006 FS2300 and the plastic tank is black if that means anything.
