rerod
Nov 06, 2014Explorer
What are these leaky featherlite doors useful for anyway?
Iv always wondered why featherlite installed small side access doors. Is it to secure a wide vehicle my ramp wouldn't support anyway?
Anyway.. Iv got a small water leak at this door. I can tell the door itself leaks, as they all do. But the problem is the latch must pass through the threshold which usually kicks water out that gets inside the door.. Now, featherlite filled this latch hole with silicone and I drilled a hole to the outside trying to drain it. But I'm still getting water in the inside after replacing the door seal.
Any suggestions other than junking the door and riveting a cover over?
Should I remove the latch and re-caulk it and the corners again and hope? After looking more it looks like the top of the door frame is getting wet..
Thanks
broken screw..
silicone filled latch hole
Thanks
broken screw..
