samandtheduck
Aug 11, 2014Explorer
SailingOn wrote:
"Some repair shops advocate bypassing the thermal fuse by adding a jumper wire. While this method does determine whether the fuse is bad, it is too easy to forget to remove the jumper and replace the thermal fuse. Instead, remove the wire leads from the thermal fuse and set a multitester to its lowest RX setting. Touch the tester’s probes to each terminal on the fuse. A reading of infinity indicates the thermal fuse is good. Any other reading means the fuse has triggered and must be replaced."
Doesn't an infinity resistance reading across a fuse indicate an open or blown fuse?
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
