- ScottGNomadUse the bottom shelf of the fridge to calibrate levels (per Dometics manual).
You don't want to start off with levels calibrated to something else (that may not be level, like a stove) because if you add the fridges level to your "stove" (or what ever else you use) you may end up being off too much overall.
Remember, the damage is cumulative so it may work fine but the damage is adding up if its too far off. Then when it's in a very hot place, it wont work. - hotpepperkidExplorer
WE-C-USA wrote:
My reference point is the range top. I don't want all my bacon grease going to one side of the skillet. :)
The refer can be off at few degrees & still work without any problems.
Yep so the eggs stay in on spot to - lakeside013104ExplorerWhen my DW's head gets level, we are good to go.:B
Lakeside - Water-BugExplorerRefridgerator needs level to operate and wife needs stove level to cook. Luckily they are usually right next to each other and ours is in the middle of the 5er.
- WE-C-USAExplorerMy reference point is the range top. I don't want all my bacon grease going to one side of the skillet. :)
The refer can be off at few degrees & still work without any problems. - ljwarnerExplorerPerfect, thanks!
- F105Explorer
donn0128 wrote:
On a refer shelf. That is the most important thing
X2 for width - I place my 3 foot level on the right side door sill for lenght wise. - donn0128Explorer IIOn a refer shelf. That is the most important thing
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
