sjturbo
Sep 20, 2015Explorer
Which Dicor for reseal/repair?
I found a few areas that need attention on my slide today. First, where the aluminum edging meets the (rubber?)roof needs resealing. I had tried the Dicor self-leveling but it was not apparently what was used originally because it rubbed off on the rubber seals when the slide went in and out. The original appears to be some type of white flexible caulk. I assume using silicone is not an option? Secondly, where the corners meet there is a gap and leak area. As well, where the alum meets the fiberglass side of the slide the standard butyl tape is sandwiched between then covered with what appears to be silicone. Lastly can I clean these areas with Acetone? So some help would be greatly appreciated.
