I have a 2011 Sunset Creek. The trailer is a highline glass panel sided unit. I had the classic water take fell out problem. The interior trim had a too good of quality problem. They ran the trim strips dead into the corners. When thermal expansion happen the strips would pop off. I cut the corners and silicone the corner. The trailer also used aviation style screw clamps on the water service connections. The clamps can't compress the thin wall hose. I changed them all to fuel injection high pressure hose clamps. The PD inverter didn't have the charge wizard installed. No way could the battery ever charge. Overall the trailer is one of the strongest construction units I have ever owned. The Crane glass panel construction adds diagonal strength better than most other types. I would recommend any of the high end Winnebago towables.
MM49
