- john_b1Explorer
MNRon wrote:
I agree with the flush line that runs into the toilet inside, and would expect the leak when you flush if not winterized properly. The exterior black flush that you hook a hose up to is the one I have never bothered with, and question the need for exotic winterizing means for this that some seem to go to.
X2 for 30 years now and no problem yet! Jb - MNRonExplorerI agree with the flush line that runs into the toilet inside, and would expect the leak when you flush if not winterized properly. The exterior black flush that you hook a hose up to is the one I have never bothered with, and question the need for exotic winterizing means for this that some seem to go to.
- VulcaneerExplorer
Paul Clancy wrote:
Definitely winterize the black flush. There is usually a backflow prevention valve that water stands in and if not winterized it will freeze and crack. Next time you flush water all over. Ask me how I know.
This is true. I probably found this out the same way he did. - Paul_ClancyExplorer IIDefinitely winterize the black flush. There is usually a backflow prevention valve that water stands in and if not winterized it will freeze and crack. Next time you flush water all over. Ask me how I know.
- MNRonExplorerWe live in MN, it gets cold here. I've never worried about the black flush line when winterizing (many years) and it still seems to work fine. I suspect it's built to drain free each time, otherwise I certainly would have seen a problem by now.
FWIW, I used the air method to winterize for several years...until one spring a few years ago I found a broken fitting under the kitchen sink (it got WET when we were just about to take our first trip of the year). Since then I've used the pink stuff...hmm...maybe it's time again this weekend... - ontheroad101ExplorerThanks for all the good tips. Medical conditions may keep us in PA longer then we would like. In the passed we would go south to winterize.
- therinkExplorerI live in Western NY and have always blown out my back tank flush with air using the same 50 cent garden hose threaded air chuck adapter. Takes about 3 seconds.
old guy wrote:
or you can just blow the line clear with air. that is what I have been doing.
X2 on this.. not a problem , just needs a couple short spurts of air to reach the black tank....- BB_TXNomad
Vulcaneer wrote:
My black tank flusher connects in the valve control area. What I do is take a short 4 foot water hose and connect the male end to the flush connection. The female connection end on that hose goes to my outside shower faucets. When I run A/F from the water pump thru the system I open each faucet one at a time. When I get to the outside shower, the pink runs thru those faucets and into the hose and in thru the black tank flusher. All in one step, and no drips. Easy peezy.
Same here. Very easy, IF you have an outside shower near by. - old_guyExploreror you can just blow the line clear with air. that is what I have been doing.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
