Coach-man wrote:
GrumpyandGrandma wrote:
If your going to G rated 14 ply make sure you have the higher pressure rims. The Goodyear 614 is a 110 psi tire.
They put 95 pounds pressure in them, estimating the weight of the rig. Good to know that the rims should be good to 123 lbs!
They probably guessed right.
Per GY tech support using the weight/inflation chart add 5psi to what the chart lists at your weight. This is when up sizing load range. I went from "E" to "G" ran 85 for for thousands of miles and had perfect were. Did the same with last MobileSuites going from "G" to "H".
