I beleive the satellite dish antenna receives, probably dc voltage, from the receiver to operate. There is a F type jack on the side of my camper labeled satellite. There is a cable tv jack next to th...
To the OP, you can connect the satellite antenna coax to that port marked Satellite and you then must find the other end of that connection and connect that directly to the receiver. It might be a wall plate with a coax connector or it might be a loose cable where ever the manufacturer planned for you to use a satellite receiver.
