luberhill's avatar
luberhill
? help on 2005 28ft Gulf Stream class C
It has 51k miles,,,no leaks, needs 4 rear tires, everything seems to work except the coach ac doesn't seem to blow much out of the ducted vents, if you open the grate on the unit itself it pours out air ???
The generator has 1100 hrs which seems like alot but it runs good
Thoughts ?
Rear walk around queen bed...
  • luberhill wrote:
    Chris Bryant wrote:
    Duct problems are fairly common- a bit of time with a flashlight, mirror and some foil tape will work wonders.
    Pls explain what to do
    Basically, remove the vents, stick a flashlight at one end, use a mirror at the other end to check for obstructions, them look at gaps between the vent and duct- seal any of those, then drop the ceiling assembly cover and look at the duct connections, seal those. Last, make sure the divider between the return and supply air is sealed.
    There have been a couple of threads about this- some with good pictures, but I cannot find them.
  • darsben1 wrote:
    Are you looking to buy it?
    If so it needs 6 tires not 4
    1100 hrs is about what I have on mine that just broke. They are expensive to repair but really reliable.
    The air pours out but is it cold?
    Yes thinking of buying it...
    Needs 4 tires NOT 6,,,the fronts are new...
    The air is cold when it comes out the grates,,,but doesn't blow much at all out of the ducted roof vents...
    What "broke" on yours at 1100 hrs ??
  • Are you looking to buy it?
  • Duct problems are fairly common- a bit of time with a flashlight, mirror and some foil tape will work wonders.
