Hank_MI's avatar
Hank_MI
'03 Winnebago Adventurer questions
Just purchased a few weeks ago, owner wasn't much help except to tell me how clean it is. Apparently he and I have different opinions regarding "clean". It's in really good shape, no abuse, everything works, just needs a very good cleaning top to bottom inside and out.
So I have a couple of questions regarding this rig. First, where is the controller for the HWH levelers? Not the control panel, the unit that determines when the unit is level. Mine needs to be adjusted as the rear and left side are high when the unit says it's level.
Second, not really important but kind of bugs me. Where is the switch for the small light above/beside the drivers seat. The one for the passenger seat has a switch on the panel next to the seat. No switches near the drivers seat.
  • Thanks again for the replies. If it ever stops raining here I'll start looking for it. So far I'm really liking this rig. Workhorse W-22 chassis, Allison trans, 8.1 liter, what's not to like. For a 12 year old rig it has just about every option you'd want and we really like the layout.
  • As a side issue:
    Please note that the 2003 chassis (W20 and W22) had a 2 inch front stabilizer shaft. Often called an anti sway bar. In September of 2003 WH changed to a 2.5 inch bar.
    If your chassis has the 2 inch bar I would strongly recommend that you have the 2.5 inch bar installed. I did and it made a huge improvement in roll or side to side sway.
    This is from an email I got from WH in 2005:
    "The part number for the Front Stabilizer Bar with Brackets is: W0005643.
    This bar was found to have an advantage over the original 2" bar, and was
    put into regular production on 9/2/2003.
    The installation is very straightforward. Remove 4 retaining nuts while
    supporting bar, remove bar, hold new bar in position, reinstall 4 retaining
    nuts, and torque to specification. This procedure is NOT meant to replace
    the service manual, but is a generalized procedure.
    The upgraded stabilizer bar has been shown to provide the following
    benefits:
    1. Reduced Body Roll when cornering.
    2. Reduced "rocking" when passed by or passing large vehicles.
    3. Reduced "rocking" when traversing bumps on an angle."
    The installation procedure is below- I did not raise the coach, just crawled under it:
    Stabilizer Shaft Replacement (Front) (W20/W22)
    Removal Procedure
    1. Raise the vehicle on a hoist
    2. Remove the nuts and washers from the stabilizer shaft clamp and the right front leaf spring.
    3. Remove the nuts and washers from the stabilizer shaft clamp and the left front leaf spring, and remove the stabilizer shaft from the vehicle.
    4. Remove the clamps from the stabilizer shaft.
    5. Remove the insulators from the stabilizer shaft.
    Installation Procedure
    1. Install the insulators to the stabilizer shaft.
    2. Install the clamps to the stabilizer shaft.
    Notice: Refer to Fastener Notice in Cautions and Notices in the WCC Service Manual.
    3. Install the washers and nuts to the stabilizer shaft clamp and the left front leaf spring.
    4. Install the washers and nuts to the stabilizer shaft clamp and the right front leaf spring.
    Tighten the stabilizer shaft clamp nuts to
    373 N·m (275 lb ft).
    5. Lower the vehicle.
  • Well now I have to see what size swaybar I have while searching for the HWH level sensor, thanks for the tip.
  • Clay L, is the anti sway bar a square tube? I don't see a conventional round shaft but a square tube near the end of both the front and rear of the front leaf springs that goes from one side to the other. I have to assume that is the anti sway bar/stabilizer.
    Yes it is the square tube.
