C-Leigh_Racing
Mar 29, 2014Explorer
The Workhorse is a pretty good chassis, the 8.1 V8 is strong, dependable & the Allison trans is backed up by many many years of service in several different types of trucks, so you'll be good to go there.
The only thing you really need to be on your toes about, are those brake issues from the past on the W18, W20, W22 model chassis, to be sure that problem has been corrected.
It may take more than just asking, if the brake issues have been corrected, maybe even need go to some records if they can be found.
During the brake recall, at first, even some of the replacement calipers were defective & those had to be replaced as well, so it was a pretty serious problem.
In all of the reading I've done on the Workhorse brake issues, the larger W24 model chassis, was not affected with the issues in the brake recall, because they used a different type of brake caliper on those.
The brake issue, was a Bosch type caliper with the non metal type pistons. Those non metal pistons would absorb moisture & under hard breaking, swell & not release the brakes resulting in sticking brakes.
Other than the brake issues on the Workhorse, if that problem has been corrected proper, I wouldnt turn around for the difference between the Workhorse or the Ford F53 chassis, because both will give you years on service.
Neil
Neil
38,766 PostsLatest Activity: Jan 10, 2026
