Ivylog
May 08, 2018Explorer III
You need to see if a rubber hose has been added to the crankcase vent tube on the side of your engine that runs behind/past the radiator. If no hose add one so oil does not get sucked up into the radiators making it difficult to clean.
If you can see solid stuff on the radiator, from inside the MH, spray with dawn and using a brush scrub until loosen and wash off downward.
38,769 PostsLatest Activity: Apr 24, 2002
