RickAvery
Jul 10, 2022Explorer
Thank you for your replys, yes, I've checked the cut-off switch and it appears to be working properly. There is also a hard disconnect in the battery compartment which disconnects the main positive lead in which case, nothing is activated and this is also working correctly.
I will check out the negative cables in the morning.
Thanks again
-Rick
Thanks again
-Rick
38,778 PostsLatest Activity: Jun 10, 2026
