RB211's avatar
RB211
'07 Southwind BR TV Removal?
One of my winter projects was to replace the older LCD flat panel TV's in the coach. The front went fine resulting in a new 32" display over the OEM Samsung 26".
The OEM 20" Samsung in the bedroom is fast becoming a problem. It's sitting on it's pedestal however it appears they used double sided tape to secure it to the shelf. I've tried to put a heat gun gently to the pedestal base and then slide a long icing spreader (I asked the wife first...) to get under the pedestal in hope of releasing the adhesive.
Doesn't want to give.....and before I do something I'll likely regret I thought I'd canvass the brain trust here for some input.
I've called the factory and they sent schematics but no mention of how it is secured down. I called the dealer and he said it was likely that it's been installed with the tape.
Thoughts?
Thanks in advance...Ron
