RicB's avatar
RicB
10K diesel Onan fault code 14
My Onan generator runs fine with the main breaker on the generator off. Turn the breaker on and it surges in/out and will finally shut down and throw a fault code number 14 which indicates over frequency.
Any ideas what to look for?
  • Ivylog's avatar
    Ivylog
    Explorer III
    Lack of fuel is a very good recommendation and changing the fuel filter is the cheapest place to start unless it is almost new. Also, the fuel pump is a know problem area, enough so that I carry a spare one along with a filter.
  • I suspect your surging under load is lack of fuel. Could be a restricted fuel filter.
    Richard
  • Ivylog's avatar
    Ivylog
    Explorer III
    I think your problem is one of the loads in your DP. Turn off all the 20 or 15 amp breakers in your 120V panel. With generator running start turning the breakers back on. Your AC/ heat pumps have a time delay so you need to wait until the compressor kicks on before going to the next breaker.
  • Disconnect everything you can from the other side of the main breaker, try again.
    Could be a bad motor in something or a bad AC capacitor in the converter. Just grasping at troubleshooting straws here..
