Returned home from 3 week trip. I plugged in my 110 15amp home power and couple of days later my wife wanted to clean the interior so I turned on the electric water heater for her needs. A few minutes...
Most likely it says 35 amps not volts.pter could have failed. Do you have an inverter? Possible that the breaker on it tripped. I am guessing your rig is 50 amp shore power and you are using some type of adapter to plug into some type of receptacle.
