1157 is the two element bulb. 1156 is the single element bulb. The side pins on both bulbs are positioned different so you have to use the correct bulb to fit the socket. RV manufacturer probably got a boat load of lights with the 1157 configuration, but the design of the trailer called for a single element bulb. So the manufacturer ran only the single wire to one element, even though the socket had wires for 2 elements. Had both elements been wired into 1 wire, I don't think it would have been much brighter anyway.
