EMaznio's avatar
EMaznio
12 Volt DC Wiring
I'm replacing the relay for our rear Dynasty slide and the new relay requires a 12V DC power source to be added to the existing switch. Basically, the In/Out Switch has 3 prongs on the backside. The center is currently grounded, but the new relay needs that to be powered with 12V DC. I need to run a new line, but am unsure what DC line I should tap for power or if I ought to leave this project up to a licensed electrician, so I don't kill myself! Thoughts or suggestions?
  • If the center is really grounded then you cant apply 12V to the outer ones or your going to make a direct short when you press it.
  • Why didnt you replace the old relay with one identical?
