jhilley
Feb 19, 2015Explorer
I would check the 12 volt ground to the chassis, maybe remove and clean the bolt and all connectors and make sure all connections are tight. Check to make sure the battery connections are clean and tight. Measure the converter output voltage, should be at least 13.3 VDC.
