Sam_Spade
Sep 11, 2017Explorer
JeLe wrote:
We can push the coach battery connect switch 'on' but it will not stay on. Thanks for any help.
VERY common problem, sometimes even for seasoned RVers.
LIkely that the switch you are pushing is the EMERGENCY switch which ties the two battery banks together as long as you keep it pushed......so you can use your house batteries to start the main engine if those batteries go dead.
There is ANOTHER SWITCH somewhere that you haven't found yet. It is usually right inside the side door. It completely disconnects the house batteries from everything. Throw that switch and you should be fine.
38,778 PostsLatest Activity: Jun 10, 2026
