timmac wrote:
So my NEW 19.5 tires say 120 lbs max but the label for specs inside motorhome say tires front and back should be 80 lbs ??
40 lbs under tire manufacture pressure seems to low, so for now I put my tires at 95 lbs, am I to high or to low ??
:@:h
What would you do if the tires maker said max pressure was 200 lbs??
With the tires that came on the rig ( tire size) inflated to what it says on that placard....will allow your coach to carry the MAXIMUM AMOUNT OF WEIGHT it was designed for...no more..no less.
Running as much higher that the specified placard card gains you NOTHING
