- SkiingSixPackExplorer
Born To Travel wrote:
Another thing those late 70s Mopars were famous for was the ballast resistors going bad.. . Back then everyone carried a spare in the glovebox.. To test it unplug both ends and take a ohm meter and check the lower one from end to end and the upper one from end to end.. If either reads open then it is bad.. One side is the start circuit and the other side is the run circuit..
Our old 1977 Dodge went through 2 of these. We kept one in the glovebox after that also. I checked mine by using a small nail we had with us to bypass the resister. It started right up, so we called the closest auto parts store and they had 2 of them. Bought both. Lucky we did!!! The second one is still probably gong strong.
This was the only time the old motor home stranded us. We had to have some carb work done and we just always had issues with re-starting after it was warm.
Good luck!!! - ezcampingExplorerA friend of mine bought an old car that had been sitting for a long time. It had some gas in it and he filled it after he bought it. On the way home about halfway it started to sputter and backfire and lose power. Pulled over to the side of the road and tried to diagnose problem. After about an hour of trying different things it started back with no problems. Drove home and just as he got home started doing the same thing. We couldn't figure it out for a long time until finally we noticed brown dust coming out of the exhaust and on further inspection figured out it was rust.
The gas tank had rust and crud in it and after driving a bit it would all come up off the bottom of tank and get in the fuel. After sitting awhile the crud would settle.and it would run again. Long story short check the tank for crud. - wildmanbakerExplorerI think Scott may have it correct. If it will start when it cools off, more than likely, the timing chain is stretched, and needs to be replaced as a full set. I recommend a double roller chain set, with gears. GMs are also guilty of this problem. If the ignition box goes bad, it usually just dies and will not start. There is a test procedure for the boxes, but I do not remember it off the top of my head. A good "Motors Manual" will have this information, and others for trouble shooting.
- 2bzy2cExplorer II
Another thing those late 70s Mopars were famous for was the ballast resistors going bad.. On the firewall will be a rectangular white ceramic looking thing with a plug on each end.. these acted like a fuse for the ignition system.. When they went bad it would not start.. Back then everyone carried a spare in the glovebox.. To test it unplug both ends and take a ohm meter and check the lower one from end to end and the upper one from end to end.. If either reads open then it is bad.. One side is the start circuit and the other side is the run circuit..
So true. I was going to write about that, but felt I was not able to give a good description of it. Back in the day, I drove a tow truck for auto club. I always carried one. Came in handy more than once.
However, the resistor will have nothing to do with the backfiring. Just the starting. - MrWizardModeratorIF bad..you can jumper around the ballast resister to start it and drive it home
then replace it, the way it works is the resistor is bypassed in start mode to provide a hotter spark from the ignition
then is 'in circuit' with the engine running, so the plugs last longer
when i had my old wedge head 413, i bypassed the ballast resistor
but i had to replace the points more often because they would burn up
plugs were no problem i just when to a heavy duty plug
your 78 440 has a different distribute, mag senor no points, but the same ignition module
buy a spare ignition module and spare voltage regulator module to carry with you
IF you have that plastic body thermo quad carburetor... replace it - Born_To_TravelExplorerAnother thing those late 70s Mopars were famous for was the ballast resistors going bad.. On the firewall will be a rectangular white ceramic looking thing with a plug on each end.. these acted like a fuse for the ignition system.. When they went bad it would not start.. Back then everyone carried a spare in the glovebox.. To test it unplug both ends and take a ohm meter and check the lower one from end to end and the upper one from end to end.. If either reads open then it is bad.. One side is the start circuit and the other side is the run circuit..
- 2bzy2cExplorer IIBackfiring is "generally" an issue with the ignition portion of the engine. Not always, but that is the first place to look.
Try getting some starting fluid and squirting it into the carb. If the engine starts even for just a second or two, then you have a fuel issue. Bad gas, clogged filter, etc.
If there is no difference after trying the starting fluid, meaning the engine refuses to run, then your problem is probably ignition.
Timing chain - Doubtful
Bad gas - maybe, but it wouldn't have run in the first place
Clogged fuel filter - Probably. If the rig has been sitting awhile, some of the gas may have gelled, broken loose and clogged the filter. (The starting fluid will confirm fuel delivery problems.)
Plugs and wires - Always a good idea to replace on an older vehicle, but to suddenly stop it from running, very doubtful.
Stuck choke - Common problem on 440's. Easy fix. Open the butterfly "flap" on the inlet of the carb if closed shut. - ScottGNomadNot uncommon for engines of that era to jump or break the timing chain when they're shut down. Your going to have to do a lot more inspection and testing before someone can just tell you what to do to fix this.
- Sully2Explorer
BelleStarr71 wrote:
Just purchased this beast. We are brand new at this so any help is greatly appreciated. Already replaced battery, but driving it from Lancaster OH to Columbus OH it decided to not start after driving it for 3/4 of the distance. The gas smells off. Engine tries to catch, but just won't. Thinking maybe bad gas? Need plugs and wires?
Gasoline has turned; Carb is gummed up; fuel line and filter need cleaning and maybe even replacing ( Filter)
Clean everything up.....replace filters....install totally fresh gasoline and dump existing gas....try it again
38,763 PostsLatest Activity: Jul 22, 2018
