Brad1111
Nov 02, 2013Explorer
I see what you mean, thanks for your insight on wiring. In addition to the best way to wire the batteries together as the website shows, i was interested in hearing about the effects of replacing a house battery with 4, and if the charge controller just going to the batteries is all i need to do. Or if having an entirely separate bank for solar is preferred.
And after some checking, it turns out this may not have an inverter anyway! I havent tried to plug anything in while driving, and have been plugged in when not. So with the lights being 12v, they have their own power thing happening. Is is tricky to wire the inverter into the battery/generator/outlet system? Do you only plug directly into your inverter, or do you have wall outlets?
38,766 PostsLatest Activity: Jan 10, 2026
