- edtoy3ExplorerThe generator is toast. I was able to figure out what wires go to the rear AC. Thanks for the help
- hostageExplorer
gbopp wrote:
What you are experiencing is normal for a rubber roof. The white covering deteriorates and washes off when it rains or if you have a heavy dew.
Depending on the age and condition of your roof, you may want to consider coating the roof. It's not a difficult DIY project. And it will eliminate the streaks.
Did you get your generator problem corrected?
no matter rubber or fiberglass they both shed white
mines fiberglass - gboppExplorerWhat you are experiencing is normal for a rubber roof. The white covering deteriorates and washes off when it rains or if you have a heavy dew.
Did you get your generator problem corrected? - hostageExplorer
edtoy3 wrote:
Hello everyone
I have a 1985 holiday Rambler! I have a white milky substance that when it rains or I wash the unit it streaks down the RV. Does anyone know the fix?
Thanks
yes go on the roof and wash/scrub the roof with a real good oxi brite type soap; when dry put a coat of floor wax (what I read) I don't bother with the wax idea I just give it a good scrub once every year or two seems to suffice
38,782 PostsLatest Activity: Sep 10, 2026
