Tommy_U's avatar
Tommy_U
1993 Chevy P30 fuel pump help
Hi All - I have a 1994 Fleetwood Southwind on a 1993 P30 chassis. Got back from 4th of July weekend and was pulling into storage the next day and just as I placed it in Park and set parking brake the engine died. After that it would not start and had 3/4 tank of gas. I used some starter fluid and it will start so it is a fuel delivery problem. Also I was not hearing the fuel pump. I am having a hard time locating the fuse / relay for the fuel pump. I have checked all fuses I can find any bad, all seem to be good. I have a Chevy service manual but it is terrible and has very little info. Does anybody have a wiring specs for a 1993/94 p30? I was having trouble with my gas gauge also so I dropped the tank and replaced the whole unit assuming it was a bad fuel pump but possible electrical. I need to start tracing the wires and checking them / possible bad ground or broken wire. The plug to the fuel pump has 3 prongs, I assume it is ground, power for the pump and sending unit signal. Does anybody know what the voltage should read for the 3 wires and which should have power when the ignition is on? Any help would be greatly appreciated cause I have a vacation planed Aug 1st and need to get this solved asap. Any suggestions on what else to check would be greatly appreciated.
