psalm10720's avatar
psalm10720
1994 Brave TV Coax re-wire
I have a 1994 Brave 27RC. The outdoor connection of the TV coax is currently on the right side in the outdoor radio compartment. Most Park hookups are on the left side alongside of the Power and Water/Sewer. Over time the current coax connector has become degraded and unusable due to moisture (I believe.) I've tried hooking up an external coax to this connector but cannot get any signal response inside...
I want to establish a new coax connection starting at the Power Cable compartment and route the coax to the splitter above the front dash and was wondering if someone has done this before?
Right now I have to run the external cable coax extension through the driver window and place duct tape over any open spaces that are left exposed through the window and I would like to run a new cable so to avoid that. I believe there's plenty of space in the power outlet compartment to add a terminal to hook up an external coax connection there.....
  • psalm10720 wrote:
    One of the ways I was thinking was to drill a hole through the top of the power cable box and attach a female connector so that I could use a male to male cable to attach to the park feed.
    Use barrel connector which is a FF coax connector. They come with a nut for mounting.
    As far as the right side connector near the outside stereo I would assume that TV Signal would feed the system from that receptacle allowing signal to go to the powered face plate above the drier/co-driver.
    I think that connection is for an outside TV. Guess you could back feed through it but I don't believe that was the intent. As mentioned, look at top of wet bay or utility hookup bay. That's where ours was on our 1994 Bounder.
  • One of the ways I was thinking was to drill a hole through the top of the power cable box and attach a female connector so that I could use a male to male cable to attach to the park feed.
  • I think that connection is for an outside TV.
    The input coax connector on Winnebago's of that era were often in the service/wet bay on the left side of the compartment up and behind a panel. You have to get down and look up to see it. I would never have found the one on my Warrior if a prior owner of it hadn't showed it to me.
  • Cut off say 12" from the existing coax and see if that resolves the problem. If not I'd run a new coax to the easiest point. While sites often have the connection in the rear DS it's not uncommon to be further forward.
    I carry 25' and 50' coax with a barrel connector so that the site location is a non issue.
  • Whichever method you use to make the new connection, be sure to use high-quality RG-6 cable. Don't skimp by buying the cheap stuff.
  • Or up the back or inside a wall or closet if you have one over the spot to inside the ceiling, using a wire snake and a wire fishing pole. Takes a little longer in the back but you end up with a nice installation.
  • Couple ways to go. You could add a thru wall receptacle up by the drivers area to get it inside the. Up. Under the dash the the windshield A pillar. This saves you from running it along the frame.
    Or you can add it to the water compartment out the back run it along the frame and up through either the floor of firewall under the dash then up the pillar.
