CC38EL
Nov 09, 2020Explorer II
Does it crank or just sit there? This is a mechanical diesel so there isn't much to them....the basic air, fuel, battery.
If it doesn't crank at all, start in the battery bay and check all your big fuses. There will also be fuses in the engine compartment where the battery cables come in from the battery box. Check those as well.
Is this a 12v or 24v system? Whichever, make sure your new batteries are wired for the voltage you need. A 12v setup will not power a 24v system.
