Ivylog
Oct 03, 2020Explorer III
I’m pretty sure a 94 Cummins does not have an electric lift pump...fill the fuel filters with fuel when changing to decrease the amount of air in the system. A common problem is the 12V solenoid that pulls the lever turning on the fuel gets weak... you can help it by pulling on the lever.
I would loosen the fuel lines at the injectors (3/4 wrench) and then over heat your starter cranking on it OR put a gas soaked rag over the air intake to get the engine to run on the gas. Takes awhile cranking to get the gas from the intake to the engine. Once you get fuel coming out of the loosen lines, tighten and start it normally.
