- turbojimmyExplorer
Gjac wrote:
What does you ride height measure from side to side? You should have at least 1.75 ins.
1.75" from where? Just curious because I often wonder about my ride height. Being able to control the rear height with the Jet Ride system has a pretty big impact on overall handling. In my "auto" setting I think it's actually sitting a little low. - I had about a 2 inch piece broken off the bottom of the right front coil spring. Found it while shop was installing Henderson Super Coils.
The fourth character in the VIN number indicates gross vehicle weight.
G= 8,001-9,000
H= 9,000 10,000
J= 10,000- 14,000
K= 14,0001-16,000
seventh character indicates style of chassis. This seems to very!
2 is forward control
7 is motorhome - GjacExplorer III
bjarnold wrote:
What does you ride height measure from side to side? You should have at least 1.75 ins. On a light 28 ft MH your springs may be fine but depending on age and miles driven the springs both front and rear do wear out and the bags alone may not be able to provide the right ride height. As Bud posted many of us had to go with a heavier duty coil spring from Henderson to lift the upper A arm off of the lower bumper stop to get the proper ride height. If it now rides nose up check the ride height in the rear your rear springs may be sagging some.
Right now I have them at 80psi. After the old bags were replaced the front end did come up noticeably. Before it looked like a hod rod with the nose to the ground. Now it is sitting just about level. I put a level inside the freezer and it's actually sitting a little nose high - harold1946Explorer
happycamper002 wrote:
Big nonsense, CW replaced the blown airbag and corrected the problem.
How do you explain that.I still have the blown air bag to prove my point.
Try to make more sense in what you say to make yourself believable.
An Rv tech doesn't make an engineer.
Doug is absolutely correct. The rear suspension of your RV has been modified by someone.
Neither GM nor Workhorse ever used air suspension, (or air assist) on the rear suspension of their chassis.
Get all the facts right and you will not be giving everyone WRONG information, and making yourself look rather inept. - turbojimmyExplorer
I'm sorry but you're confused. Chevy put air bags inside the FRONT coils on the P-30 chassis to compensate for the load that the motorhome places on the front axle. When they manufactured the chassis they didn't know whether it was ultimately going to be a motorhome, bread truck or whatever. They are a band-aid of sorts - the right thing to do is to size the coil springs to the load on the front axle. Both my front bags are blown and the rig sits just fine. Handling is a bit sketchy - bags are on the to-do list. I've been driving it for years with no bags despite dire warnings in the manual that the front tires will shred pretty much immediately (didn't happen).
Rear bags, as mentioned, did not come from the factory. The factory setup on the P-30 was rear leaf springs. Nowhere to put bags even if you wanted to (EDIT: there are air bag helper spring kits, but not for the big truck chassis that I'm aware of). Some manufacturers and owners opted for aftermarket airbag systems that completely replaced the stock leaf springs. In this case, the airbag is taking the place of the spring rather than just providing a bit of help it as with the bags in the front coils. If a rig equipped with a rear air bag system blows, it will drop to the ground. I'm surprised you were able to drive yours. I have a slow leak in my right rear bag (Jet Ride air suspension) and when it leaks out completely (takes a few months in storage) it's sitting right down on the ground.
So this blown bag you have - is it a big black thing or a skinny red thing? - happycamper002ExplorerBig nonsense, CW replaced the blown airbag and corrected the problem.
An Rv tech doesn't make an engineer. happycamper002 wrote:
darsben1 wrote:
This is the correct answer.
This is misinformation that shouldn't have been. You obviously haven't experienced a blown air bag on one side. I have the same size MH that OP has and I blew the passenger-side rear bag while driving from a lakeside CG in CA.
I couldn't stop on a single lane steep mountain road to check, and besides, there wasn't much I could have done anyway so I kept driving until I got to the nearest town. I pulled into a gas station and the best advice I got from the mechanic was I needed new shocks. (duh)
All that time I was driving from the mountain road, I got some well-meaning motorists behind me motioning that I'm leaning over to tip the MH due to bad off-level condition.
I have also witnessed school buses with blown air bags with the chassis almost touching the pavement.
I deflated the opposite side air bag to almost even out the off-level side to make it home that was almost 100 miles away.
My motor home and I assume most of them are, has almost all the weight on the passenger side: water heater, range, fridge, kitchen cupboard, 32 in flat TV, hood, propane tank and even the motorized doorstep. And to make things worse, the road crown is always sloping to the passenger side making liquid in tanks like fuel, waste and fresh water to settle or nest to that side too.
Weighing an empty RV doesn't reflect the real world condition.
I always check the level and pressure to achieve the level that I'm comfortable with. It doesn't have to be perfect but at least motorists behind you would not be concerned about you falling over the cliff when driving the shoreline of the Pacific Ocean in Northern CA.
Yes, to a certain extent, it does help in keeping the MH level.
You state you had a problem with REAR airbags. YOU obviously do not know what you are talking about. There is a difference between the P-32 and the OLDER P-30 Chevy chassis. As I stated, on the P-30 chassis, the inside the FRONT coils, CHEVY installed the Air bags to INCREASE the front load capacity of the Front end. Chevy never installed REAR air bags on a P-30 chassis, but some OEM Class A makers did. The CHEVY P-30 chassis REQUIRES operational air bags for correct front end handling. You can use aftermarket air bags which a lot of people do. I worked on Chevy Class A motorhomes from 1979 until about 1991, when we dropped chassis service. I STILL am a RV Technician and have been for 37 years. Doug
AND, your statement about Load distribution. Poppycock. It all depends on the floorplan and the OEM maker on how appliances and various items are installed on the RV. They do NOT load up the pass side or even one side as a standard design. They DO try to equalize the load distribution to some extent.- ets1996ExplorerMy understanding of the airbags on my p32 chassis is to adjust ride height. I have some instruction some where which states aside from weight axle/corners of the motorhome should be unloaded storage, tanks etc. then on flat parking Measure bumper height front and rear Then with coach loaded for travel use the airbags to return to empty ride height with out exceeding max air pressure rating.
Yes, to a certain extent, it does help in keeping the MH level. - I replaced my front springs with variable coils with no air bags from Henderson lineup.
38,706 PostsLatest Activity: Feb 03, 2025
