BluegrassBill's avatar
Jun 10, 2015
1995 Chevy 454 intermitant hard to start
I have owned my 1995 Itasca 29 since 2002. It has 73,000 miles on it now. The engine has always been easy to start. Now It randomly is hard to start. Cranks strong but nothing, After cranking and cranking it will fire up and die unless you can catch it by pumping the throttle rapidly. Once running after a few seconds it runs normally. Goes down the road with plenty of power. I changed out the Engine Coolant Sensor, No change. I then checked the MAP sensor with a vacuum gauge and volt meter, It is within specs. The sparks plugs are new as are all wires ,coil and Distributor cap with MSD parts. The TBI is spraying fuel onto the throttle plates as it is cranking. Friends I am stumped. Any ideas. Many Thanks, Bill
