- bartrakExplorerI checked them with an ohm meter and all showed a circuit.
- tiogaearl31ExplorerHad the same problem. All fuses good. Turned out to be clock switch. Ford repair shop indicated that this was a common problem.
- bartrakExplorerI drove the rv again today and the ABS light came on but when I would stop and turn the engine off the light would go off but would come back on when I restarted . Does that affect the cruise control ? I am in process of trying to see why the light comes on, I suspect a sensor somewhere ?
- navegatorExplorerDo not forget to check the switch on the brake pedal, it has to be closed making contact this is what turns the cruise control off when you step on the brake, it has an adjustment nut.
navegator
38,705 PostsLatest Activity: Jan 14, 2025
