Aramerman's avatar
Aramerman
1996 Georgie boy cruisemaster 34'
I recently acquired a 1996 georgie boy cruisemaster. It has an f53 chassis. I am having issues with the ignition switch feed fuse blowing. I can't seem to locate the short. Twice I have had it towed to ford and both times the problem seems to not be occurring by the time I get there.
It now just blew In my driveway while backing it up. As as I put in the new 60a fuse and turn the key to accessory it blows. The dealer checked the alternator, it seems fine. All wires look good.
Any ideas?
  • If it is blowing the Switch fuse it is probably an issue between the switch and the fuse block. Most of the rest of the items are fused separately and you should be blowing the individual fuses long before you blow a 60 amp fuse. I think one of the previous poster suggested that you pull the switch and test the lines to determine which one has the bad leg. You may have to trace a couple of junctions if it off your accessory leg. I have had similar issues with various vehicles over the years and most turned out to be a pinched or abraded wire under the dash, several but not all were steering column pinches.
  • Disconnect the batteries
    Pull the fuse
    Crawl under the dash and start measuring resistance to frame ground on All wiring connected to the accessory circuit
    This could include stereo, heater blower, a/c etc...
    Even relay power to the hyd levelers
    The one with zero resistance is your short
    You might need an extra long wire to go out a window and connect directly to some chassis steel for the frame ground connection
    Get an f53 Chilton manual to help yo find the accessory fuses and wiring harness connections
  • its the switch itself shorting out to ground try using just 1 key not a bunch of keys hanging.Sometimes its the wire itself at the ignition
