enblethen
Oct 13, 2013Nomad
You should be able to check the relay holder for power on the contact pin. If power is present you could jumper to the output pin location to see if pump will run.
It may not run if your filter on line is plugged or restricted.
Some MHs have a connector adjacent to the fuel tank for the pump and gauge.
38,706 PostsLatest Activity: Feb 01, 2025
