dougrainer
Jun 17, 2018Nomad
1. YOU NEVER USE THE JACKS TO RAISE THE MOTORHOME OFF THE GROUND TO CHANGE TIRES---PERIOD!
2. Any Tire store that would do it, should not be changing motorhome tires and I would not want them changing my tires.
3. I cannot believe that any qualified tire store would want the liability or even their insurance company would allow this type operation if they knew about it
4. A QUALIFIED Tire Store will have the correct Jacks to raise the RV to safely change the tires.
5. 3 point systems were designed to STOP chassis twisting at the front cap area. There are 2 designs of this type system. The first is the single front jack that is centered and cannot twist the frame when extended. The 2nd is a Powergear system that used 2 jacks up front with 1 solenoid and an equalizing T that caused BOTH front jacks to extend the same. The weight of the motorhome equalizes the front to prevent twisting. Doug
38,782 PostsLatest Activity: Aug 31, 2026
