dgendeavor's avatar
dgendeavor
1999 holiday Rambler Endeavor
Hi I'm am new to this forum. I really could use some help. I'm trying to locate the side out control box on my holiday Rambler. We have the power gear set up on our side. Does any one know where it is mounted on this year coach. Thanks Doug
  • I looked under the dash again. With the million wires. Lol. I don't see anything I opened up the plastic door panel if you call it that and nothing there but the air line for the parking brake and wires for the transmission.
  • I have pulled the switches out and there is nothing behind it. Just the wires going into the wall and headed to the floors. I'll check under the dash again. Thanks for the suggestions! Doug
  • I am currently running a 2000 Endeavor. I have never looked for the control board for the slide out, but thought I could offer a couple of hints. The board for the Power Gear Jacks is under the dash in the area where your left foot is when sitting in the drivers seat. Maybe that board controls both or the slide board is in the same area. Another place I'd look is behind the switch for the slide in the cabinet.
  • I looked in that area. I just don't see it. My daughter and I have been looking high and low over the coach for this thing with no luck. The wires are almost impossible to trace. like a new car they don't make things easy to fix. Ugh.
  • Hey Dennis thanks for replying. Yes I'm trying to locate the slide out control box. Power gear thinks it may be my problem and wants to run some test on it. I have yet to find it. I will look around the step tomorrow. Thanks Doug
  • Welcome to the forum, Doug. I've read your post and really don't understand what you're asking. Are you looking for your SLIDE control box? If so, look under your steps....Dennis
