DSDP_Don
Dec 02, 2017Explorer
Unless you changed to a higher ply rating, you'll not see enough of a difference to g back to Michellins. As others said, check your air pressure. These tires may need to be run a few pounds lower. Have you actually checked the pressure or just trust that the installer put in the correct amount of air.
38,769 PostsLatest Activity: Dec 31, 2014
