- RiverrattralphExplorer
WILDEBILL308 wrote:
Yes what Born TO Travel said. Common set up for high dust environments. Get both filters. I even have the same setup on my lawn mower.
Bill
It is not a foam prefilter. Where can you buy the metal filter? - RiverrattralphExplorer
- WILDEBILL308Explorer IIYes what Born TO Travel said. Common set up for high dust environments. Get both filters. I even have the same setup on my lawn mower.
Bill - RiverrattralphExplorerMy top picture is the inner filter which is a metal type screen and the second picture is the normal paper typed filter that goes around the outside of the metal one
Born To Travel wrote:
It is a throw away paper filter... Take the part number off of it and buy a new one.. The outer filter is a pre-filter...
No it is not. look at it closely. The outer filter is the usually throw away filter but there is the inner one that is made of a metal screen type material that seams to be fastened to the housing and not removable - Born_To_TravelExplorerIt is a throw away paper filter... Take the part number off of it and buy a new one.. The outer filter is a pre-filter...
- darsbenExplorer II
Riverrattralph wrote:
darsben wrote:
enblethen wrote:
The inner air filter cannot be cleaned. It is a replaceable paper unit.
Air filter
No the outer is replaceable the inner is permanent.
What is the purpose of the inner filter? I would think there should be a way to clean it.
That is what the op is asking HOW do you clean the thing.
My rig has one that I just blow out with an air gun. But I wanted to see if others had a better answer because I do not know the correct procedure either. The inner on mine is NOT oily so it is not an oil bath unit in my opinion but I do not know the correct answer - RiverrattralphExplorer
darsben wrote:
Air filter
What is the purpose of the inner filter? I would think there should be a way to clean it. - darsbenExplorer II
Air filter
38,763 PostsLatest Activity: Dec 13, 2025
