2ndhom wrote:
Seems simple but not sure of the best spliter to use. Have my Direct Sat Box in front of the coach feeding front TV. Want to feed the bedroom TV from same box. I know I can't watch 2 separate programs with one box. Want to watch TV after we've hit the sack for the night or both TV's on at same time. The coax is already run and ready to go. Looking for best spliter to use without degrading quality of picture. Thanks all!!
It all depends how many LNB's you have. If you have a Dome generally they only have one LNB, but if you have a dish then it is possible you have all three LNB's to where you can watch one program in front and a different on the rear. But if you only have on LNB and only one receiver then you can only watch the same program that is in the front tv in the rear. Now if you have two receivers one for the front and one for the rear then it is my understanding you can watch two different programs at the same time on Direct TV. You can not do that with Dish because they have two separate satellites.
I just switched to Direct from Dish and I have to watch the same program that is on the front in the rear because I have the Kingdome and it only has one LNB, and I only have the front receiver/DVR in the front.
My coach does have a selector box to switch from ANT to Aux and Sat.
