Marv_Hoag's avatar
Marv_Hoag
2000 Monaco 12 volt replacement bulbs
My Monaco has ceramic sockets for small 2 prong 12 volt bulbs. I have tried to find replacement bulbs, but they fit loose in the ceramic socket. The center prong on the original bulb is larger than the replacement bulbs from the local RV store. Has anyone else had this issue and found the correct replacement bulb? Hard to make something loose work correctly.
The difference in size ( the part that goes into the socket ) is almost not noticeable, but really really affects the fit in the ceramic socket. The part that goes into the socket is flat.
  • They are most likely G4 bulbs. Cheapest place I've found them is Amazon. You can get a pack of 10 at a reasonable price. There is also an LED version at Amazon from Kindeep (20 watt) for $17 for 10. Very good match to the color and output of the halogens.
  • Ivylog's avatar
    Ivylog
    Explorer III
    I replaced all of my halogen bulbs with $1 G4 leds from China on EBay. Found the 12,chip 5050 round disks in warm white worked the best BUT the halogen bulbs had round pins. Putting a small bend in the round pins might make them fit tighter.
  • For old Monaco parts, try Alliance Coach in Wildwood, FL They bought the old Monaco factory service Center in Florida and they had bins of this type of stuff.
    Another thing to do is look on ebay and aliexpress.com for led bulbs to match. They are cheap and use a lot less power and are way cooler(temperature) than the halogens that were there originally.
  • RoyF wrote:
    The LED bases were too big because of a lump of solder (is that the right spelling?)
    Yes it is. :)
  • RoyF wrote:
    I have the opposite problem. I ordered LED bulbs to replace C921 incandescents. The LED bases were too big because of a lump of solder (is that the right spelling?) on each wire, but I can file or scrape the solder to make them fit.
    Maybe adding some solder to your bases might work.
    The bulb I have is made of glass, no metal base.
    No numbers on the bulb. Going to call Monaco tomorrow, maybe they can help.
  • I have the opposite problem. I ordered LED bulbs to replace C921 incandescents. The LED bases were too big because of a lump of solder (is that the right spelling?) on each wire, but I can file or scrape the solder to make them fit.
